View Entity Child Indexes
- Select Entity.
- Select the Child Index tab.
Child Index Field Descriptions
Use the data in the following table to use the Child Index tab.
Name |
Description |
Index |
Indicates the index of the entry. |
ChildIndex |
The index of the entry. The value of Physical Index for the contained physical entity. |
